  New Posts New Posts RSS Feed - access to sql conversion problem
 Post Reply Post Reply Page  <123>
thekiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thekiwi Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2004 at 7:49pm
On the SQL Server CD.  You install these tools to your local PC to allow you to administer SQL Server from anywhere (eg across your LAN or to a remote WWW Server
Badaboem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badaboem Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2004 at 7:52pm
How do I do it is a completely different question compared to where do I find it  + use google...you'd be surprised how much you can find by just searching.
http://support.jodohost.com/showthread.php?t=157
it seems they don't have an ''online tool'' to view database contents. Download as described above.
Edited by Badaboem
Post Options Post Options   Thanks (0) Thanks(0)   Quote thekiwi Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2004 at 7:55pm
PS
YOu can download the EVal version of SQL Server ... which will have Ent Manager ... but it will be illegal to use Ent Manager beyond the trial date .... but I'll leave that up to you
http://www.microsoft.com/sql/evaluation/trial/default.asp
nguyencno5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nguyencno5 Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2004 at 8:00pm
oh kool... thank you very much.. :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote thekiwi Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2004 at 8:02pm
Im probably wrong, but I believe the Visual Studio came with a "Version 7" of Ent Manager ... and this wont connect to SQL2000.
Try this for some options
http://www.aspfaq.com/show.asp?id=2442
You might also find this site useful http://www.aspenterprisemanager.com/ they ahve an online version of their alpha release
Edited by thekiwi
dpyers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpyers Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2004 at 11:13pm
If you have IIS and the .net framework on your local PC MS "Web Data Administrator" to manage MS SQL DB's from a browser . Free and very slick.
http://www.microsoft.com/downloads/details.aspx?familyid=f0d 03472-5e6c-459e-a6d8-6745a729c3c9&languageid=f49e8428-70 71-4979-8a67-3cffcb0c2524&displaylang=en
for Access DB's using asp , try Stp Database - http://www.stpworks.com/DesktopDefault.aspx?tabid=8&tabi ndex=4&stpdl=view&ItemID=1
Edited by dpyers
Lead me not into temptation... I know the short cut, follow me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nguyencno5 Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2004 at 4:10am
wow.. thank you all very very much!!!!
you guys are all big help!!.. i'm trying it right now.. if anything else come up I know where to find help
Post Options Post Options   Thanks (0) Thanks(0)   Quote nguyencno5 Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2004 at 8:59pm
 Can you guys also help me on this.. I still getting the error below when running WWForum (registration new user).
Microsoft OLE DB Provider for SQL Server error '80040e2f'
Cannot insert the value NULL into column 'Author_ID', table 'mySQL_database_name.dbo.tblAuthor'; column does not allow nulls. INSERT fails.
Thanks in advance!
