  New Posts New Posts RSS Feed - access to sql conversion problem
 Post Reply Post Reply Page  <123
otti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote otti Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2004 at 5:50am
Originally posted by nguyencno5 nguyencno5 wrote:
 Can you guys also help me on this.. I still getting the error below when running WWForum (registration new user).
Microsoft OLE DB Provider for SQL Server error '80040e2f'
Cannot insert the value NULL into column 'Author_ID', table 'mySQL_database_name.dbo.tblAuthor'; column does not allow nulls. INSERT fails.
Thanks in advance!
I am also trying to get my access db working on ms-sql the error you get I got also. I solved it by editing the table design thru enterprise manager. you have to make the column author_id in table author to integer with auto increment = 1
otti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote otti Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2004 at 6:17am
insert registration: error solved
delete error solved
I just uploaded the file delete_post.asp again and it worked. that is strange though because the old file worked fine with the access version !!!
I still have the error of DB statistics (I uploaded the file again but doesn't work)
new error New user
A new registered user gets problems while try to do these things:
- view the profile
- send pm or read pm that new user send
- post new message
and more problems
all those problems seems occurs because of default values in table author like join_date = now() and it should be getdate() for ms-sql
same thing with column no of posts etc...
I fixed the problem with new registration by editing table desing my self,  is there an better way to convert the table author into ms-sql?? instead of having to edit all columns manually??  are there other tables that will need editing??
thanks in advance
