  New Posts New Posts RSS Feed - Fix for a skin related problem.
Awes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Awes Quote  Post ReplyReply Direct Link To This Post Topic: Fix for a skin related problem.
    Posted: 21 October 2003 at 10:19pm
With my skin I need class=smText to be white.  The problem is the Quick Login text is coded for smText in the default.asp file also.  This means you cannot see what you are typing in the login form fields.
I could play around with it, but want some opinions for the best fix.
Thanks in advance.
MadDog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadDog Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2003 at 10:52pm
add this to the css file at the bottom,
input {color : #000000;}
Awes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Awes Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2003 at 7:40pm
Tried that MadDog but didn't help... Every other field input is alrady black, just white on the Quick Login.
Thanks for the reply though!
wistex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wistex Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2003 at 7:42pm
You could create a new class just for that.  Just change the class of whatever you want to change to a new class you create and then create an appropriate entry in the css. Then there won't be any conflicts.
Awes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Awes Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2003 at 8:54pm
Thanks, that's exactly what I did to make it work but had to modify the default.asp file with the new class.  Guess if I share it I'll include the default.asp file or instructions for the code to change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2003 at 2:27am
Take the CSS style off the input box for the quick login. Remove the following part:-
class=""smText""
