  New Posts New Posts RSS Feed - no registration
no registration
coolatta75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coolatta75 Quote  Post ReplyReply Direct Link To This Post Topic: no registration
    Posted: 19 October 2004 at 11:42am
I did a search and came up empty.  I'd like to have my users simply post without registering.  Is this possible?  TIA.
huwnet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote huwnet Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2004 at 11:57am
enable guest posting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coolatta75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2004 at 12:13pm
I'm sorry, but i don't see that feature of enabling or disabling "guest posting" anywhere in Administration.  I'm using version 7.7a.  Please advise.
dpyers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpyers Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2004 at 2:57pm
Don't have 7.7a, but I think it's hasn't changed.
Go into group permissions from the admin panel.
Lead me not into temptation... I know the short cut, follow me.
MadDog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadDog Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2004 at 3:47pm
The best thing to do is 1) search, 2) post in the correct forum (the support forum in this case).
dj air View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj air Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2004 at 3:47pm
It is advised to update to V7.8  or V7.9 now. as there are some security holes in the application before V7.8.
only a few files have been changed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coolatta75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2004 at 4:21pm
Found answer to my own question.  Go to Forum Admin, choose a Forum, and then all the permissions are under Generic Forum Permissions.
