Here is the "fix"
Edit the file forum_post.asp and replace the code on line 1254 ( about, don't have the original code now ) you will find the line starting with
if blnAdmin or blnEdit then
Response.Write(vbCrLf & " <a href=""edit_post_form.asp?PID=" & lngMessageID & "&PN=" & intRecordPositionPageNum)
If lngPollID > 0 AND intThreadNo = 1 Then Response.Write("&POLL=" & lngPollID)
Response.Write("" & strQsSID2 & """ rel=""nofollow""><div>" & strTxtEditPost & "</div></a>")
end if
I have set if(datediff("n",dtmPostDate,now())<15) then to allow the editor only to edit the post within 15 min.
'Only let the user edit the post if they have edit rights
If blnAdmin Then
elseif blnEdit then
'Edit only within 15 minutes
end if
End If
