  New Posts New Posts RSS Feed - SQL Statement????
SQL Statement????
choshour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote choshour Quote  Post ReplyReply Direct Link To This Post Topic: SQL Statement????
    Posted: 25 June 2003 at 9:12am
Trying to write an sql script to sort my teams by rating.  Problem is I have to use the avg feature and distinct feature to get the average for each team.  It then sorts it by teamname instead of rating.
rs.Open "SELECT DISTINCT TeamName, avg(rating) AS Average_rating FROM ratings GROUP BY teamname
It will not let me group by Average_rating
gives me This error
Microsoft][ODBC Microsoft Access Driver] You tried to execute a query that does not include the specified expression 'TeamName' as part of an aggregate function
You can not use order by with DISTINCT
Edited by choshour
pmormr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pmormr Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2003 at 10:17am
why don't you average everything after you select everything?
Post Options Post Options   Thanks (0) Thanks(0)   Quote choshour Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2003 at 11:08am
How could you sort it then?
I figured out how to do it though.  I used the max () feature and it worked.
rs.Open "SELECT DISTINCT max([TeamName])as Team, avg(rating) AS Average_rating FROM ratings GROUP BY teamname ORDER BY avg(rating) DESC"
