  New Posts New Posts RSS Feed - header.asp problem: Flash menu not displayed on IE
hassanx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hassanx Quote  Post ReplyReply Direct Link To This Post Topic: header.asp problem: Flash menu not displayed on IE
    Posted: 26 April 2006 at 7:06pm
I modified my header.asp file to put a flash menu on every page of forum.
The menu works great with Mozilla Firefox but with Internet Explorer it's not shown. I just wrote the EMBED code inside header.asp what should i do more? Thanks..
venki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote venki Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2006 at 2:19pm
install flash player on IE..
Post Options Post Options   Thanks (0) Thanks(0)   Quote hassanx Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2006 at 6:28pm
It is installed.. But still doesn't work. Just a grey box appears..
Adrina View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adrina Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2006 at 8:53pm
How does the code look like?
It should look somthing like this:
Quote
<object type="application/x-shockwave-flash" data=" %FLASH FILE URL% " width=" %WIDTH% " height=" %HEIGHT% ">
                  <param name="movie" value=" %FLASH FILE URL% " />
                  <param name="quality" value="high" />
                  <embed src=" %FLASH FILE URL% " width=" %WIDTH% " height=" %HEIGHT% " quality="high" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash"></embed>
</object>
The PARAM-tags are used by IE and the EMBED-tag are used by Mozilla FF/Netscape/Opera/(IE). most browsers works with just PARAM but it's advisible and it dosn't hurt to use both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hassanx Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2006 at 10:51pm
It worked.. thanks Smile
