This has been a problem for all sites using flash a while now. MS lost a lawsuit although the plaintive had no way of benefiting from a win so we all got screwed. A google will turn up several methods for dealing with it.
The method I use is to include the following line after the last active x control on a page.
<script type="text/javascript" src="/iefix.js"></script> |
iefix.js is in the root folder and contains
objects = document.getElementsByTagName("object"); for (var i = 0; i < objects.length; i++) { objects.outerHTML = objects.outerHTML; } |
Never tried it with wwf, but I'd put the script line in footer.asp.
Allowing users to upload flash is a disaster waiting to happen though.
