  New Posts New Posts RSS Feed - HELP HELP HELP
HELP HELP HELP
prigozu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote prigozu Quote  Post ReplyReply Direct Link To This Post Topic: HELP HELP HELP
    Posted: 05 December 2003 at 8:26am
Hi Guys,
I am trying to import the forum posts from Access to SQL but i can't import any members into SQL because the username Administrator and guest is there as a default and it won't let me overwrite them, can anybody tell me how to delete them from the forum.
Thank you
michael View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michael Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2003 at 9:00am
First, "Help Help Help" in the Subject line is not letting anyone know what your problem is so you might want to try having a more descriptive Subject.
To your problem, if you do the import you need to enable Identity Insert on the SQL side and overwrite desination data. You can also just leave the current Administrator account and update it manually skipping the one from your access database. If you are using DTS I recommend the first as it is just one click to enable identity insert.
simpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simpson Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2003 at 9:01am
Maybe if you changed your headline to something which has something to do with your problem, people will help. How can you expect people to view a topic called "HELP HELP HELP"!!! Please edit it ASAP!
PS. Have you done a search on "access to sql"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote prigozu Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2003 at 12:19pm
Sorry for the subject guys, i was able to solve the sql problem, thanks for your help.
