  New Posts New Posts RSS Feed - Help with Error on SQL DB when running
 Post Reply Post Reply Page  <12
nguyencno5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nguyencno5 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2004 at 7:02pm
thank you all.. it did fix my problem.. My forum is running on SQL now..
Thanksssssss!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2004 at 7:12pm
Originally posted by Jesper Jesper wrote:
ok... I've figured it out.
There's a bug in the creation of tables on the MSSQL server on Borg's behalf.
The Author_ID column in the tblAuthors table is set to 'integer'. In the Access version this is 'autonumber'. I set the Identity property of the column to 'Yes', Identity seed to 1 and finally Identity increment to 1.
That fixed that problem  ... I'm not too sure if that solution causes other problems ? Borg?
There isn't a bug in my SQL server creation file, see the following line from the file sets the Author_ID field to interger; Indentity, incrementing by 1 and not allowing nulls:-
strSQL = strSQL & "[Author_ID] [int] IDENTITY (1, 1) PRIMARY KEY  CLUSTERED  NOT NULL ,"
Jesper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jesper Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2004 at 2:14am
Wierd, I'm puzzled why the table we created without setting the identity property
