  New Posts New Posts RSS Feed - Post Method To Call / Chain To ASP Is Failing
 Post Reply Post Reply Page  <12
san1965 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote san1965 Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2009 at 7:23am
Hello WebWiz-Bruce,
Thank you for your guidance; very much appreciated!
I copied all the material to a sub-folder within the the wwwroot folder of inetPub, which virtually brings the program within the IIS web server environment. Now it looks like the chaining to .asp has begun happening. So, running an .asp file in IIS web server means "to bring the .asp file in some area within the wwwroot." Or may be set the folder where the .asp file is located as a "Virtual Directory" (perhaps).
The .asp file crashed with the message - "
Cannot update. Database or object is read-only.". The line at which it crashed is - "rsAddComments.AddNew". How do I change the attribute from "read-only" to "be able to do anything" for this database? I shall be grateful as always for your guidance in this.
Thank you in advance...
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2009 at 9:39am
You need to set read, write, and modify permissions on the directory that the Access database is within.
The page below should give you more help on this:-
Setting up the Correct Permissions on the IIS Web Server
