Problem Downloading
URL: https://forums.webwiz.net/forum_posts.asp?TID=10502
Printed Date: 08 April 2026 at 11:10am
Topic: Problem Downloading
Posted By: Chris7
Subject: Problem Downloading
Date Posted: 18 May 2004 at 6:53pm
I keep getting
An Error has occured while attempting to download a file.
Direct download links of Web Wiz Guide products and applications are not permitted.
when I try to download (from UK & US sites). I have a Norton firewall, but turned it off and it makes no difference
I also have a (registerred) old copy of WebWiz forum which I was planning to ditch and replace with the latest one - could that be causing the problem?
Otherwise - I could order the CD version but I'm guessing the old database won't work with version 7.8
Posted By: michael
Date Posted: 18 May 2004 at 7:34pm
Are you having a problem downloading or using the application?
http://baumannphoto.com" rel="nofollow - Blog | http://mpgtracker.com" rel="nofollow - MPG Tracker
Posted By: Chris7
Date Posted: 18 May 2004 at 8:02pm
I can't download even with Norton switched off I get
and it links me back to the WWF site
Posted By: Chris7
Date Posted: 18 May 2004 at 8:24pm
OK - Ignore all that, even though I turned Norton off on my PC, I'm connected through a server where someone has installed a firewall without telling me
