Problem: Guest post error
URL: https://forums.webwiz.net/forum_posts.asp?TID=17052
Printed Date: 16 April 2026 at 6:30am
Topic: Problem: Guest post error
Posted By: Per..
Subject: Problem: Guest post error
Date Posted: 27 October 2005 at 2:09pm
I am running Wiz forum 7.9. MS Access?
I have a forum in which I would like all users to write.
But when a guest try to post he get this error:
Microsoft JET Database Engine error '80040e21'
You cannot add or change a record because a related record is required in table 'tblAuthor'.
/post_message.asp, line 756
I wonder if itīs becuace my guest has author_ID 134 in database
I hope someone have the answer
Date Posted: 27 October 2005 at 2:13pm
When a guest posts they use the built in guest account.
The built in guest account needs to have the Author_ID of 2 in the database, and the admin Author_ID of 1
If you change either of these your forum will not only be insecure, but fail to run correctly.
Posted By: Per..
Date Posted: 27 October 2005 at 2:35pm
Thanks for the quick response!
hmm.... cant I just replace user_id=2 to user_id=134?
Posted By: aks427
Date Posted: 27 October 2005 at 4:27pm
If you do, you will have to change a lot of code.  The guest account ID is hardcoded into the forum.
