bug in v8.01
URL: https://forums.webwiz.net/forum_posts.asp?TID=19400
Printed Date: 12 April 2026 at 4:04am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: bug in v8.01
Posted By: angel
Subject: bug in v8.01
Date Posted: 18 April 2006 at 5:02pm
i have setup a mysql version om my home server (win2k3 with mysql 5 and myodbc 3.5.1), i started to translate te system into hebrew yesterday for maddog, for the beta 2 portal, but when i try to write in heb i see only question marks, i tested the access version and the mysql version'access works just fine, but mysql dont want to work with heb, the problem isn't in the database system'becuase i have other systems which works just fine with mysql with heb on the same server.
------------- soon
Date Posted: 18 April 2006 at 5:43pm
Have you edited the browser encoding file to change page encoding to that of Hebrew?
------------- https://www.webwiz.net/web-wiz-forums/forum-hosting.htm" rel="nofollow - Web Wiz Forums Hosting https://www.webwiz.net/web-hosting/windows-web-hosting.htm" rel="nofollow - ASP.NET Web Hosting
Posted By: angel
Date Posted: 19 April 2006 at 1:35am
yes i have
------------- soon
Date Posted: 19 April 2006 at 10:17am
Then I'm afraid that as I have never used Hebrew with mySQL I don't know of anything else to suggest.
Posted By: angel
Date Posted: 19 April 2006 at 3:17pm
ok, then i'll try to find a way to solve it
------------- soon
Posted By: angel
Date Posted: 20 April 2006 at 4:32am
i have found a solution for the problem, while creating the database tables (with mySQL_server_setup.asp) i creat the tables with the charecter set of hebrew
------------- soon
Date Posted: 20 April 2006 at 9:28am
Thanks angel, I will have to remember that incase anyone else has this issue.
