Loop or different way?
Category: General Discussion
Forum Name: Database Discussion
Forum Description: Discussion and chat on database related topics.
URL: https://forums.webwiz.net/forum_posts.asp?TID=26992
Printed Date: 29 March 2026 at 8:51am
Topic: Loop or different way?
Posted By: ctytrungloi
Subject: Loop or different way?
Date Posted: 16 February 2009 at 6:43am
Hi all,
I post on MySQL forum but no one answer
http://forums.devshed.com/mysql-help-4/loop-or-different-way-590979.html" rel="no follow - http://forums.devshed.com/mysql-help-4/loop-or-different-way-590979.html
  http://www.sieuthi77.com/main/nhakhoa.html" rel="no follow - nha khoa . com/showthread.php?t=23423
I'm quite unsore how to proceed with following task:
Lets assume I generated array with numbers (3456, 3333, 1234, 1114).
Now I would like to ask DBA by sql what names are attached for IDs mentioned in array.
The question is how gid data form DBA. Should I insert the Select statement into FOR loop? = 4x select .... where id=$number[$i]???
or
just select all records from DBA and compare the IDs by php code?
Regards and thx for help
Date Posted: 16 February 2009 at 9:25am
No best way is to use SQL to get just the ids you want:-
WHERE ID= first_number OR ID = second_number, etc.
Posted By: louis2609
Date Posted: 01 September 2011 at 4:50am
Originally posted by ctytrungloi ctytrungloi wrote:
Hi all,
http://forums.devshed.com/mysql-help-4/loop-or-different-way-590979. - http://forums.devshed.com/mysql-help-4/loop-or-different-way-590979.html
nha khoa. com/showthread.php?t=23423
or
Well, you can go to SQL and adjust the IDs. Then it will be ok
