Groups Ladder System
URL: https://forums.webwiz.net/forum_posts.asp?TID=28191
Printed Date: 02 April 2026 at 4:42am
Topic: Groups Ladder System
Posted By: slog
Subject: Groups Ladder System
Date Posted: 01 January 2010 at 9:44pm
I am not sure if it is a problem or if it is supposed to work like that, but I use the ladder system this way, when a member register in my forum, after the adm activate him, he need to post in a presentation topic, this we can know our members better, after that he will be able to surf thru all other topics and areas.
My problem is, the presentation topic is moderated, but after a member posts there his post count goes to one, moving him to another group. In my undertanding, a post should only be counted after its approval, but that is not the way my forum is doing it. Am I right?
If the forum should work like that, is there a way to change it to only count posts after approval?
Thanks
Date Posted: 03 January 2010 at 2:07pm
This is the way it is built to run at the present time and can not be changed.
Posted By: 123Simples
Date Posted: 03 January 2010 at 3:49pm
The way around this Slog is very simple
You have created a New User Group, and restrict that new group to say 10 posts and one forum. When they have posted and you get an idea of what they are like, simply transfer them to a Non Ladder Group which opens up your other forums to them
http://www.123simples.com/" rel="nofollow - Visit 123 Simples Web Design
Posted By: slog
Date Posted: 03 January 2010 at 11:40pm
Thanks Bruce and MrTWS. I believe that i will have to do it like MrTWS says, move the user to a no ladder group manually.
