Admin Login
URL: https://forums.webwiz.net/forum_posts.asp?TID=4145
Printed Date: 02 April 2026 at 9:53am
Topic: Admin Login
Posted By: SamoanOnion
Subject: Admin Login
Date Posted: 08 July 2003 at 7:28pm
ok, I did read the documentation for setup and admining the forum, my only problem is that my password doesn't work...
I've tried:
login:  Administrator
pwd:  letmein
both with and without caps for the 'A' in administrator but no luck, plz help, anyway I can get to that account and reset it???  all comments and help much appreciated, thanx in advance...
http://www.samoanonion.com
Posted By: kbannon
Date Posted: 09 July 2003 at 1:43am
can you not have the forum email it to yourself?
I don't suffer from insanity, I enjoy every minute of it.
Date Posted: 09 July 2003 at 8:10pm
i've tried using the "forgot password" feature, but it says that my email doesn't match with the user name .  any ideas how I can reset it or to see what it actually is???
Posted By: fishern
Date Posted: 10 July 2003 at 1:43am
I Have exactly the same problem, is there an answer yet as I would love to get up and running in the demo, so that my company can consider registering the product.
Date Posted: 10 July 2003 at 2:41am
That is the only password and username for the admin account, unless you have changed it it should be correct.
Also if using the SQL server version (you didn't say) check that the database is created correctly and that in the tblAuthor table there are two accounts created, the admin one and a guest one.
Date Posted: 10 July 2003 at 11:41am
I've tried using the given login and password but it still doesnt work.  I am able to register other users, but thats no good if no forum topics exist.  Im running it on Win XP Pro and I'm using access dbase.  I would like to get it running cause it looks like a sweet forum, so plz, any help would be much appreciated...
Posted By: INF_
Date Posted: 10 July 2003 at 11:05pm
If you don't have any data yet, just overwrite the database with a fresh copy, then login with the default info.
Date Posted: 10 July 2003 at 11:31pm
i've tried that several times and no luck.  I even downloaded the packaged a few times just incase the file(s) got corrupted while downloading and still now luck.  thanx tho.
Date Posted: 11 July 2003 at 11:11am
Open the database in access and have a look in the table tblAuthor it should have an admin account in there.
Date Posted: 11 July 2003 at 11:35am
I see the admin account, but how can I change the password, its all garbled up (encrypted i'm assuming)???  also, I opened up the dbase and put in my email address in the email address column for the admin account and tried to use the forgot password option and it gave me this:
 ServerObjectCreateObject: - Error 'ASP 0134 : 80004005'
Invalid ProgID attribute
C:\Abyss Web Server\stuff\webwiz\forgotten_password.asp, line 2757
The object has an invalid ProgID of 'CDONTS.NewMail'.
any suggestions???
Date Posted: 15 July 2003 at 9:30pm
ok, I still cant get the password to work, but to save some space I'll ask this here...
I was thinking about converting from snitz to wwg, I did the search and what is meant by comparing the dbases, I am using access 2000 dbase.  also, reading some of the old posts, I couldn't find a way of converting snitz to wwg.  by comparing the dbase does that mean, I just copy the data over to the wwg dbase and it'll work that way.  just trying to get  a work around since the admin login isn't working for me for some strange reason.
Posted By: michael
Date Posted: 16 July 2003 at 7:21am
You can manually reset the password, just register a user and remeber the password. Take the password and the salt value from that user and overwrite the one in the admin fields, that should let you in.
For the Snitz conversion, Depending on what version of Snitz you have; the later version has encrypted pwd's itself so it would be hard to convert the users including passwords. The topics and threads can be done with the import wizard, though be careful about the relationships so do it in the right order.
http://baumannphoto.com" rel="nofollow - Blog | http://mpgtracker.com" rel="nofollow - MPG Tracker
Date Posted: 16 July 2003 at 12:04pm
um, does anyone know if this my web server is the problem???  I'm using Abyss Web Server (plz let me know if you know of a different free web server that supports asp and/or php), don't know if that would make a difference or not, but I tried to register and cut n paste the password n salt value to the admin account and it still didn't work.  another thing I thought was wierd is that after I registered, I couldn't login as that registered user even though I know it worked, hmmm...
still trying though
Date Posted: 16 July 2003 at 4:52pm
ok, I think I figured it out.  I don't think it works with Abyss Web Server.  I had other apps not work with it either for some odd reason.  anyway, I am running a different web server and it works like a champ .  thanx for all the help folks, and sweet app wwg dudes, keep on keep'n on.
Date Posted: 24 July 2003 at 7:15pm
OK, just wanted to update this thread just in case someone else uses Abyss Web Server out there.  they now have an updated version that WWG forums works with (provided you have ActiveHTML installed with it), I went back to Abyss after I downloaded the update and it works like a champ.
