Who has the bigger Access forum
URL: https://forums.webwiz.net/forum_posts.asp?TID=5988
Printed Date: 03 April 2026 at 9:37am
Topic: Who has the bigger Access forum
Posted By: likedon
Subject: Who has the bigger Access forum
Date Posted: 26 September 2003 at 6:57am
It have probaly been asked before, but I didn't mangae to find a tread.
Who has the bigger WWG-forum running on access?
I've one with +5000 posts and 160 members and it still runs like at charm.
Can be seen here:
http://www.thegreenpride.dk/forum/ - http://www.thegreenpride.dk/forum/
So how high kan it go on Access?
Date Posted: 26 September 2003 at 7:02am
I've heard of ones being over 100Mb in size.
But the size that it can get up to and your forum still performs and runs OK depends on your server. If you are on your own high spec server with no other sites then 100Mb won't be a problem. But if you are on a shared web server then 10 to 15Mb would be a more reasonable maximum size.
Posted By: fastfred
Date Posted: 26 September 2003 at 7:43am
My forum has 7200 postings and about 10,5 Mb in webspace.
501 members and concurrent maximum was 42 visitors and no problem (performance) at all.
I am using a shared web server.
Check on http://www.mtb-sport.nl/forum/default.asp - http://www.mtb-sport.nl/forum/default.asp
Posted By: pam b
Date Posted: 26 September 2003 at 7:51am
Not quite as good as the stats above but still not bad,
ive got nearly 5000 posts, 319 members, and most online was 33 acording to online stats, and 57 acording to matrix live stats.
And yeah still works sweet as a nut, DB is currently 5.6
regards,pam
Posted By: God_Struth
Date Posted: 26 September 2003 at 10:11am
Our Access stats before going to SQL version (which is the best thing we ever done) were:
80,000+ posts
650 ish members
10-30 online 24/7
105 most online.
Any problems we had with slowness of the forum was usually evident at 6pm UK time when the dial-up users came on, other than that it worked like a charm!
If you have the chance to use SQL version I highly recommend it, beats Access hands down every time.
Posted By: likedon
Date Posted: 28 September 2003 at 9:08am
Ok, thanx for the replies, I'll post back in this tread (if I can find it) when i reach 15.000 posts.
Posted By: DragonFist
Date Posted: 28 September 2003 at 10:52am
my forum has
70,000 Poasts
4,000 Topics
1200 Registerd Users
15-150 Online Users 24\7
Record: 149
but as you know from my topics today it stoped working yesterday =\
Legends Live Forever
