Important: CDate Error
URL: https://forums.webwiz.net/forum_posts.asp?TID=6192
Printed Date: 03 April 2026 at 11:38am
Topic: Important: CDate Error
Posted By: e-XPLoDeR
Subject: Important: CDate Error
Date Posted: 06 October 2003 at 4:03am
http://www.e-xploder.net/forum/forum_posts.asp?TID=233&PN=1 - http://www.e-xploder.net/forum/forum_posts.asp?TID=233&P N=1
Please look at this page. It gives CDate error. I've tried to change Session.LCID = 1033 and Session.LCID = 1055 (Turkey)  in common.asp, but it still gives error.
What can i do? Please help...
Web: www.e-xploder.net
Date Posted: 06 October 2003 at 5:19am
This is a different CDate error to that in the documentation.
To prevent this error you need to disable the edited by wording in posts, This can be done from the Forum Configuration page in the admin section.
Updating to version 7.5 should also stop this error from occuring.
Date Posted: 06 October 2003 at 5:26am
Thanks -boRg-.
But I've turned off edited by wording as you say before. But it still gives the same error. I've sent an e-mail to hosting corp. about subject. (There isn't 1055 LCID on server). But I know, nothing will happen If 1055 is located.
What can I do else?
Date Posted: 06 October 2003 at 5:32am
Plus, I don't want to update v7.5 now a days.
Or I can ask this. Which files should I update in v7.5 to prevent from this error?
Date Posted: 06 October 2003 at 6:05am
The post giving this error will just have to be deleted then and the edit by feature turned off so it doesn't happen again.
Date Posted: 07 October 2003 at 1:03am
Ok.
Thanks.
