  New Posts New Posts RSS Feed - Problem Help Me..
Problem Help Me..
 Post Reply Post Reply Page  <12
cr*piecorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cr*piecorn Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2003 at 4:39pm
mmzz ? your site sais , wwg forums , the fastest forums ... well it's a good forum but most def not fastest , take for example the .net forum on str8dogs site , it's way faster .. and forums like invision,..
Ruben Schepers
http://www.crapiecorn.be
Bluefrog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bluefrog Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2003 at 4:30pm
Originally posted by michael michael wrote:
Cat_ID int
Cat_Nm varchar(xx)
SubCatOf_ID int
That way, if it is a main category it has NULL as SubCatOf_ID so you display it, the you loop through the values that have SubCatOf_ID = Cat_ID and so forth. This way you save space and can have unlimited subcategories.
This might be a bit late, but...
When implementing what Michael posted above, you can get an unlimited depth as well.
e.g. Programs >> Utilities >> Compression >> Non-Lossey >> Command Line >> ETC...
What you do is keep the top level as NULL and for each sub or sub-sub category you add it to one or more categories or sub-categories. Depending upon what sort of speed you want, either an SP or an SP and a custom component would work best. You can insert all multiple entries for each sub-cat - i.e. the sub-cat belongs to sub-cat1, sub-cat3, and sub-cat14. Also add it to sub-cat5 if sub-cat14 belongs to sub-cat5. That creates a lot of records though. A custom component would let you do that ordering much faster than ASP would. So when you look through sub-cat5, you get it because sub-cat14 is a subset of sub-cat5 and your item belongs to sub-cat14. This can get rather messy though. A semi-real-time approach may work better, i.e. write an admin page that publishes (writes a file, e.g. my_list_x.inc) an include only when you choose to update it. If you are adding things administratively, then this may be a better approach than the mess I described above. The end result is that you do your query once a day versus whenever a new visitor request the page.
Hope that wasn't too much of a tangent...
farrukh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farrukh Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2003 at 10:51pm
 nice help guy but i have to remake my database.
or what i do is i have created the table Category >> Components >> and then Sub_Categories.
in Sub_Categories there are Sub_Cat_ID, SubCategoryName, Category_ID(from Category table), Component_Id(from component table) and then i introduce a new field by referencing your advice SubCategoryof(holds a Sub_Cat_ID).
i think by this way it is possible to create unlimited subDirectories.
Please FeedBack If i was wrong
i have collected some nice avatars (37) and smileys (227) here you can download
http://www24.brinkster.com/webmastertool/download.html
