o.k i know why i am on aprivate host and this is for a free host
this is the lines
'Set up the forum cookie name
'(This is useful if you run multiple copies of Web Wiz Forums on the same site so that cookies don't interfer with each other)
Const strCookieName = "WWF"
'Encrypted passwords
'This will make your forum unsecure from hackers if you disable this!!!!!
'This can NOT be changed once your forum is in use!!!
'You will also need to directly edit the database to type in the admin password to the Password field in the tblAuthor table at record position 1
'also edit both common.asp files to change this variable
Const blnEncryptedPasswords = true
'Create database connection
'Create a connection odject
Set adoCon = Server.CreateObject("ADODB.Connection")
'--------------------- Set the path and name of the database ------------------------------------------------------------ --------------------
Virtual path to database
strDbPathAndName = Server.MapPath("admin/db/online.mdb") 'This is the path of the database from this files location on the server
'Physical path to database
'strDbPathAndName = "" 'Use this if you use the physical server path, eg:- C:\Inetpub\private\wwForum.mdb
'BRINKSTER USERS (Web Wiz Forums only works with free Brinkster accounts, not for the paid accounts)
can i take the web wiz forum for paid host and put my db ?
thanks PaKa pAkA team
Edited by =PaKapAkASiTE=
