  New Posts New Posts RSS Feed - Problem when changing ISP
Spede View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spede Quote  Post ReplyReply Direct Link To This Post Topic: Problem when changing ISP
    Posted: 24 August 2003 at 4:18am
My old ISP supported Access 2002 databases and I therefore use the access 2002 version of the database. My new web space provider though supports only access 2000. I converted the Database using MS Access 2002 to Access 2000 file format. Now everything else in the forum works except the file default.asp. Everything else works really fast but default.asp gets a timeout error after a long time. The database is quite big, about 30 000 posts.
Edited by Spede
Bliss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bliss Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2003 at 11:56am
After the conversion, you may have to compact and repair the database.
Hehehe...
