  New Posts New Posts RSS Feed - Problem with dropdown box
stevem2003 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevem2003 Quote  Post ReplyReply Direct Link To This Post Topic: Problem with dropdown box
    Posted: 21 January 2004 at 7:10am
Hi,
I am at present using the code below to get the dropdown box to populate with data from an access database.
However I would now like to create a second dropdown, but I would like the data displayed to depend on the choice of the first box.
Example: If I choose colours in box one, box two only shows colours.
In my database I have the following data:-
id    system    query
1     internet   admin
2     internet   project
3     intranet   admin
4     intranet   project
Code:
<% Option Explicit %>
Dim adoCon, strCon, rs, strSQL, strID
strID = Request.QueryString("select1")
if strID = "" then
Set strCon = Server.CreateObject("ADODB.Connection")
Set rs = Server.CreateObject("ADODB.Recordset")
strCon.Open "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" &Server.MapPath("db")
strSQL = "SELECT * FROM table ORDER BY system ASC"
rs.Open strSQL,strCon
<html>
<head>
<title>Combo Test</title>
</head>
<body>
<form method="POST" action="next.asp">
<table border=0>
<tr>
<td>System</td>
<td>
<select size="1" id="select1" name="select1">
While NOT rs.EOF
<option value="<%=rs("system")%>"><%=rs("system")%>&l t;/option>
rs.MoveNext
WEND
</select></td>
</tr>
</table>
<input type="submit" value="Submit" name="Go">
</form>
</body>
</html>
rs.Close
strCon.Close
set rs = Nothing
set strCon = Nothing
else
Response.Redirect strID
end if
Any Help, Suggestions, or tutorials would be appreciated.
Steve
aalavar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aalavar Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2004 at 10:33am
If you want an easy way to do it, and you don't need both drop down boxes to appear on the same page, then simply use a form and send the result of your first drop down box to a second page.  On the second page, request the querystring, and use that to populate the second drop down box.  If you want them to be on the same page, the coding is a little more difficult, but can still be done.  I'm not entirely sure what you are trying to accomplish, so if you could be more specific, I will try to help.
Semikolon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Semikolon Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2004 at 10:44am
this should be easy with some javascript.. but dont ask me about that.. js is not my strongest side..
Bluefrog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bluefrog Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2004 at 11:13pm
I use javascript to dynamically change drop downs. Have a look at the bottom of the page here:
http://maven3d.com/en/show_the_product.asp?PID=1
or go here:
https://maven3d.com/secure/product_zoom.asp?PID=1
Select 1 and continue to the next page.
You have to select a country before you can get shipping rates. Same basic problem.
The HTML is too much to post here. Just have a look at the source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevem2003 Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2004 at 5:33am
Many Thanks everyone for your help
