  New Posts New Posts RSS Feed - problem with forum 7.7a and 7.9
faiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote faiz Quote  Post ReplyReply Direct Link To This Post Topic: problem with forum 7.7a and 7.9
    Posted: 24 June 2004 at 8:40pm
Plz help please help????
I have pig problem with May Forums when any one he need to register they can't? I have ver. 7.7a also after downloaded new version 7.9 I can't unzip it??
Please help my, I loose a lot of my visitors?
Regards,
FAIZ
dj air View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj air Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2004 at 6:43am
Firstly Please can you not double post the same topic. Please refer to the foum rules.
in regards to the topic.
you say that they can't register, is there an error message (server one) or does it say registrations suspended or insufficiant permissions.
have you done any modifications on the forum.
BoLt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BoLt Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2004 at 7:10am
You may need to get the latest win zip or winrar to unzip it. I use winrar this seams to work ok with the downloads.
http://www.rarlab.com/
BoLt (Computer Engineer)
I suffer from Dyslexia, it means I can not spell to well not that I am thick.
www.welshlens.co.uk
thekiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thekiwi Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2004 at 2:12pm
This is going around in circles.
* Could we please accept that the files on the download sites AREA OK
* If you have a corrupted file, its becaus it didn't download correctly.  No amount of using different compression software is going to change that.
Mart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mart Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2004 at 3:21pm
99% of the time when an archive is corrupted it's because you are using a 'download manager' which manages to ruin the file when it joins the file back up
faiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote faiz Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2004 at 2:35am
Yeas I did?
I change direction to RTL
It gives me this message:
Sorry, the Security Code entered did not match that displayed.
A new Security Code has been generated.
Please ensure that cookies are enabled on your browser
When it give me this message I try to register in Web Wiz Forums and it's registered, that's mean there is no problem with option in my browser?
PLZ your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj air Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2004 at 2:02pm
faiz, i have asked you already in the above post, please can you not double post, and also NOT create new topics about the same subject.
please note that whjen you submit a post to the support forums that it needs to be approved. this is why it is not visable.
are you using the default pages that came with the forum. Also, make sure that your webserver is up to date and is capable of using all features.
Edited by dj air
faiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote faiz Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2004 at 8:41am
Hi all
I find my problem?
When I convert html to html dir=rtl for register.asp, it not allow any on to register!!!?
Way and how can I solve it?
Please your help
FAIZ
