  New Posts New Posts RSS Feed - Problem with web Wiz forum
£lectro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote £lectro Quote  Post ReplyReply Direct Link To This Post Topic: Problem with web Wiz forum
    Posted: 23 November 2006 at 11:31am
Hi everyone I am new here !
I just want to Install this forums on my website but Im getting this problem :
Server Error in Forum Application
An error has occured while executing SQL query on database.
Please check that the MySQL Server version is 4.1 or above.
Please contact the forum administrator.
Support Error Code:- err_mySQL_get_birthdays
File Name:- default.asp
Error details:-
Microsoft OLE DB Provider for ODBC Drivers
[MySQL][ODBC 3.51 Driver][mysqld-4.0.27-standard-log]You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '(tblAuthor.(
please give me any idea wat to do ??
thanxx
Mikey View Drop Down
1979
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2006 at 1:18pm
Quote
Your not using a supported version of MySQL, you need 4.1
Edited by Mikey - 25 December 2006 at 10:30pm
Handyman man?
