  New Posts New Posts RSS Feed - Problems after installation & conversion
NickeL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickeL Quote  Post ReplyReply Direct Link To This Post Topic: Problems after installation & conversion
    Posted: 29 April 2003 at 11:08am
Having upgraded from v6 to v7 and having used the database migration tool it looks as if everything works with all existing posts and users visible. However, an error occurs on any new posts:
Microsoft JET Database Engine error '80040e21'
The changes you requested to the table were not successful because they would create duplicate values in the index, primary key, or relationship. Change the data in the field or fields that contain duplicate data, remove the index, or redefine the index to permit duplicate entries and try again.
/forum7/post_message.asp, line 749
Any ideas? I'm assuming that there is something that I have forgotten to do
Edited by NickeL
zadax View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zadax Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2003 at 12:00pm
Db Currept
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2003 at 12:02pm
Before and after upgrading the databases coompact and repair both databases in access.
You can find this under the tools menu in access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickeL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2003 at 2:09pm
Problem Sorted
I tried compact & repair before and after conversion without success.  I then changed to the Access 2000 version and the problem went away.
Apparently my ISP's Access 2002 support is quite what it should be.
Thanks for the suggestions anyway
dgulbransen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgulbransen Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2003 at 3:24pm
I am having this problem to.
So what did you do? You went from access 2002 to 2000 and it worked?
Mongoose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mongoose Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2003 at 3:38pm
I had this problem to...
tried to convert to 2000 .
without any luck...all users ...now need to register all over = the migration went bad....
Blade- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blade- Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2003 at 4:16pm
I had this same problem when upgrading because originally I installed the forum utilizing Access 2000 and I was trying to upgrade to Version 7.0 final utilizing Access 2002.  I toyed around for a while and then downloaded the Access 2000 version of the new forum and the site ran fine.
May or may not work for you, but it did for me.
Blade
Edited by Blade-
ljamal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ljamal Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2003 at 8:13pm
It sounds like the post table just needs re-indexing. I haven't work with Access in a long so I'm not sure how to fix it exactly but the problem can be fixed and there is no need to start re-registering people.
You should however maintain a copy of your database before doing any conversion. Always mainatin a duplicate of the database.
