We created an account in Brinkster and a problem occured in the forum, the Google Ads appeared inside the "New Post" text box.
I contacted the Brinkster support and the chat is:
info: Please wait for a site operator to respond.
info: You are now chatting with 'David'
David: Thank you for contacting the support department. How may I help you?
Douglas:
Is occurin a problem on My site, is a thing that appeared from
brinkster and is causing a problem on my forum, what happen is: when a
person whrite a message in a text box, the message is preceed of a lot
of characters
David: I suggest that you evaluate your code and try to fix this.
Douglas: in the realy is the google adversitment that appear in the message
David: You can evaluate your code to fix this.
Douglas: wait a minute please.
Douglas: that appear with the message, and this is not in my code:
Douglas:
var google_language="en"; var adHB=true; < =
src="http://www.brinkster.com/adplace.js"> wDoL("top","AAKF730");
wCls("AAKF730"); wDoL("btm" ,"AAKF730"); showA("AAKF730");
David: Again, you should evaluate your code to fix this.
Douglas: but it is NOT in my code!!!!!!!!!!!
Douglas: I have a manner to do not display that thing in my text box?
Douglas: hello?????
David: Brinkster cannot change the ads. Please evaluate your code.
Douglas: I searched in my codes and i didnīt found anything appeared with this
Douglas: Can you take a look at my site?
Douglas: http://www50.brinkster.com/agx66/forum/
Douglas: take a look
Douglas: it destroyed my site...
Douglas:
I FIND THE ERROR: Is in the http://www.brinkster.com/adplace.js, if is
to put ADS, put in a correct manner. Alright, its free, but I thinked
it the Brinkster is a serious Corporation, and not give apropriated
support to its clients. I believe it was better.
David: You will need to change your code to fix this.
Douglas: What code?
David: Your code.
David: http://www50.brinkster.com/agx66/forum/
Douglas:
when i will write a message, inside my text box appear the
adversitment, it is not generated in my code, but in the Brinkster
Server. I am rigth?
David: Your code may be referring to frames or external files (or other technology).
David: Thank you for contacting Technical Support. If you require further assistance, please let us know.
have a manner to fix the Problem?
My Site is
Please take a look in the Wonderful error!!!!!!!!!!!
