  New Posts New Posts RSS Feed - SQL Problem
SQL Problem
Pegaso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pegaso Quote  Post ReplyReply Direct Link To This Post Topic: SQL Problem
    Posted: 25 April 2003 at 1:21am
The following didn't work. Why??
strSQL = "SELECT tblNewsRating.News_ID, Avg(tblNewsRating.Rating) AS MediadiRating "
strSQL = strSQL & "FROM tblNewsRating "
strSQL = strSQL & "GROUP BY tblNewsRating.News_ID "
strSQL = strSQL & "WHERE tblNewsRating.News_ID = " & rsnews("News_ID") &";"
That's the error message:
Tipo di errore:
Microsoft JET Database Engine (0x80040E14)
Errore di sintassi (operatore mancante) nell'espressione della query 'tblNewsRating.News_ID WHERE tblNewsRating.News_ID = 117'.
/Ticinorally/testing2.asp, line 52
thanks to all for the help
Edited by Pegaso
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pegaso Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2003 at 1:28am
Sorry I have found now the solution. And for all that have the same problem, here you have the solution:
strSQL = strSQL & "HAVING tblNewsRating.News_ID = " & rsnews("News_ID") &";"
If you work with a Group you must use Having and not Where.
MorningZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MorningZ Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2003 at 11:17am
actually thats not true, you can have
SELECT.. FROM .. WHERE... GROUP
"having" isn't absolutely required
Contribute to the working anarchy we fondly call the Internet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pegaso Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2003 at 8:28am
OK but with the WHERE command the SQL didn't work and with HAVING it works. Why?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MorningZ Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2003 at 8:33am
notice i didnt say: replace "HAVING" with "WHERE"
there's more than one way to skin a cat
