  New Posts New Posts RSS Feed - SQL Problem
SQL Problem
justinp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justinp Quote  Post ReplyReply Direct Link To This Post Topic: SQL Problem
    Posted: 11 June 2003 at 4:29am
Hi,
I'm using an Access 2002 DB accessed via ASP.
This is my SQL query:
SELECT *, GoalsFor - GoalsAg AS GoalsDif FROM tblTeams ORDER BY TotalPoints DESC, GoalsDif DESC
I'm using an alias(GoalsDif) in the SQL query above to create a sum of two columns in my db table. The problem I'm having is that it wont let me sort the table by the alias GoalDif. It works fine with just TotalPoints DESC but not with GoalsDif DESC.
Can anyone let me know where I'm going wrong please??
Many Thanks
Justin
michael View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michael Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2003 at 3:34pm
In Access you can only sort on columns that exist not on virtual fields. Your query has a flaw anyway and I am sure will not work as you expect it to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote justinp Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2003 at 5:00am
Hi Michael,
Thanks for your reply. I've sorted the problem now. A friend emailed me this the morning:
SELECT tblTeams.*, ([GoalsFor]-[GoalsAg]) AS GoalDif FROM tblTeams ORDER BY tblTeams.TotalPoints DESC , ([GoalsFor]-[GoalsAg]) DESC
It does the trick.
Thanks
Justin
