  New Posts New Posts RSS Feed - Strange problem :( 2 clicks b4 it works!
 Post Reply Post Reply Page  12>
MrCarl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrCarl Quote  Post ReplyReply Direct Link To This Post Topic: Strange problem :( 2 clicks b4 it works!
    Posted: 13 February 2004 at 12:34pm
Hi,
I have setup a form which has a search textbox which you can either leave blank to search for all, or enter a number for it to query the database with.
It all seems to work fine, except if I put a number into the textbox I and click the submit button it doesnt query the database correctly and stays the same, but if I click it a second time it works!! really strange... Please helpn and let me know where im going wrong!!
Here is the code...
Thanks
- Carl
<%@ Page Language="VB" Debug="true" %>
<%@ import Namespace="System.Data" %>
<%@ import Namespace="System.Data.SqlClient" %>
<script runat="server">
 Sub Page_Load(sender as Object, e as EventArgs)
 End Sub
 Sub subPurchaseOrderSearch(sender As Object, e As ImageClickEventArgs)
  Dim conSql as New SqlConnection(ConfigurationSettings.AppSettings("strCon"))
  Dim strSql as String = "SELECT tblPurchaseOrders.intPoNumber, tblPurchaseOrders.datRaised, tblPurchaseOrders.decAmount, tblPurchaseOrders.strStatus " _
        & "FROM tblPurchaseOrders "
  Dim sbSqlWhere as StringBuilder = New StringBuilder()
  If Not frmOrderNo.Text = "" Then sbSqlWhere.Append("WHERE tblPurchaseOrders.intPoNumber = " & frmOrderNo.Text)
  Dim comSql as New SqlCommand(strSql & sbSqlWhere.ToString(), conSql)
  conSql.Open()
  dgPurchaseOrderList.DataSource = comSql.ExecuteReader(CommandBehavior.CloseConnection)
  dgPurchaseOrderList.DataBind()
  conSql.Close()
 End Sub
 Sub subPurchaseOrderView(sender as Object, e As DataGridCommandEventArgs)
  Dim idJobVacancy as Integer = Convert.ToInt32(e.Item.Cells(0).text)
  Response.Redirect("PurchaseOrderView.aspx?id=" & idJobVacancy)
 End Sub
</script>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title>Westmead - Driven by the Future</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link href="/sty/MainStyle.css" type="text/css" rel="stylesheet">
<script language="javascript" src="/inc/incFormFunctions.js"></script>
</head>
<body>
<form enctype="multipart/form-data" runat="server">
  <asp:TextBox id="frmOrderNo" tabIndex="2" runat="server" CssClass="form" AutoPostBack="true" MaxLength="10" TextMode="SingleLine" />
  <asp:ImageButton AlternateText="Click here to search for vacancy" id="ImageButton" ImageUrl="gfx/button_search.gif" runat="server" tabIndex="6" OnClick="subPurchaseOrderSearch" />
  <br>
  <asp:datagrid id="dgPurchaseOrderList" runat="server" CssClass="tableStyle1" AutoGenerateColumns="false" BorderColor="#000000" BorderStyle="Solid" CellPadding="5" CellSpacing="0" Width="100%" OnItemCommand="subPurchaseOrderView">
    <HeaderStyle cssclass="bold" />
    <AlternatingItemStyle cssclass="tableRow2" />
    <ItemStyle cssclass="tableRow1" />
    <Columns>
    <asp:BoundColumn DataField="intPoNumber" HeaderText="P/O Number" />
    <asp:BoundColumn DataField="datRaised" HeaderText="Date" />
    <asp:BoundColumn DataField="decAmount" HeaderText="Value" />
    <asp:BoundColumn DataField="strStatus" HeaderText="Status" />
    <asp:ButtonColumn Text="View" HeaderText="View" />
    </Columns>
  </asp:datagrid>
</form>
</body>
</html>
Diep-Vriezer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diep-Vriezer Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2004 at 4:12pm
Looks like you're temp. inet files are filled or something. Try displaying the results on another page, and it won't happen again. How to solve it.. Hmm. Try deleting your temp inet files, then rebuild (or rerun) the application and see.
Gone..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diep-Vriezer Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2004 at 4:14pm
Btw, the conSQL.Close() isn't needed, since you're closing the connection using Commandbehavior.CloseConnection right?
Gone..
Mart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mart Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2004 at 4:26pm
I had a similar problem once, can't think off hand how I solved it... I will get back to you if I remember.
michael View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michael Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2004 at 5:49pm
Actually the opposite, with commandbehaviour.closeconnection you explicity tell the page that you will close the connection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diep-Vriezer Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2004 at 6:41pm
Gone..
Bunce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bunce Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2004 at 9:51pm
That option will close the connection when you close the reader.
There have been many, many posts made throughout the world...
This was one of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michael Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2004 at 10:15pm
