  New Posts New Posts RSS Feed - Using SQL Distinct.. Help!
nkewney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nkewney Quote  Post ReplyReply Direct Link To This Post Topic: Using SQL Distinct.. Help!
    Posted: 08 October 2004 at 10:50am
Hi there,
I was hoping someone could help me with a problem I have with an SQL query.
There are some instances in the database where there are entries with the same 'item_product_code', but with different prices depending on the item_stone_field (see sample below)
What i need to do is get some SQL to return all UNIQUE item_product_code fields, and if there are more than one, just list the first. (The rest will be dealt with in another query).
item_id item_supplier item_product_code item_ cat_finish  item_cost_price  item_stone
28 2  1016   Sterling   6.95   green
29 2  1016   Sterling &nb sp;6.95   black
30 2  1016   Sterling   4.95   blue
33 2  1014   Sterling   4.95   blue
This is my latest attempt which unforunately doesn't work!!
Sql = "SELECT DISTINCT(item_product_code), item_cost_price FROM Products WHERE Products.item_cat_prodtype ='" & insBrowse & "' GROUP BY item_product_code, item_cost_price "
Any suggestions?
Cheers
Nick
theSCIENTIST View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theSCIENTIST Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2004 at 8:14pm
SELECT TOP 1 ... should do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nkewney Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2004 at 2:55am
Will 'top' work if i want to return the first of every similar entry in the table?
Nick
Mart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mart Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2004 at 3:59am
Not for that, no. Can you run it through query analyser and show us the output and tell us what you want it to look like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nkewney Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2004 at 12:44pm
Thanks for your help so far.
This is the query I'm using...
SELECT DISTINCT (item_product_code), item_cost_price
FROM Products
WHERE Products.item_cat_prodtype='rings'
GROUP BY item_product_code, item_cost_price;
This is the result I'm getting.
(I only require the first of any duplicate product code, ommitting any further entries...)
item_product_code item_cost_price
1007 6.35
1008 4.75
1016 4.95
1016 6.95
1018 6.25
1018 6.95
1022 9.95
1023 3.95
1023 6.50
1026 7.50
