  New Posts New Posts RSS Feed - work around for css body tag problem
mtm81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtm81 Quote  Post ReplyReply Direct Link To This Post Topic: work around for css body tag problem
    Posted: 07 July 2006 at 10:56am
Hi,
I've made my forum to be integrated into an existing site.. in doing so I had to alter the body class of the forum style sheet so as to show my gradient background which is shown on the background of each page..
(the forum itself is then within a table with a white background)...
all working, but only problem is that the quick post box obviously used the body class to get it's formatting etc.. so it's showing the gradient background in there which makes reading the text as you're entering it impossible...
how do I stop the quick reply box (and other parts of the forum that use that same box) for using the body class?
James
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2006 at 2:20pm
Try editing the file RTE_textarea.asp and removing the class from this file.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtm81 Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2006 at 3:55pm
that did it..
I removed the reference to the standard CSS file and instead just replicated that WebWizRTEtextarea class on the page direct..
this removed the body tag from being loaded as a part of the main stylesheet...
thanks!
Mikey View Drop Down
1979
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2006 at 5:23pm
All i did was set a seperate color for the text area.
Handyman man?
net55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote net55 Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2006 at 5:36am
I know this post is a little old but I just ran into the same problem. Here's what I did.
Make it an image background.
.WebWizRTEtextarea{
 background-image: url('img/1x1white.gif');
 background-color: #FFFFFF;
 font-size: 12px
