  New Posts New Posts RSS Feed - Group Permissions not working - no check boxes
 Post Reply Post Reply Page  12>
jhonrath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhonrath Quote  Post ReplyReply Direct Link To This Post Topic: Group Permissions not working - no check boxes
    Posted: 17 July 2006 at 2:12am
I am trying to use web wiz forums for the first time.
The check boxes are not even SHOWING UP for any of the group administration permissions.
IS this something that must be paid for?
I have tried installing 3 different times, from 2 different Web Wiz downloads (SQL Server version) with ZERO results.
The whole table row that should be showing the check boxes is missing, but the headings are showing up!
Thanks for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2006 at 10:14am
This is very odd, on what page in the admin section are you getting this problem?
Also, make sure the forum is uploaded correctly using FTP.
lolila View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lolila Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2006 at 3:51am
May be it is very odd, but I get the same problem too. version:8.03.
I can only get the name of Group Permissions, but there are no the row of value of permissions.
Check it out, please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2006 at 9:12am
Again, please say what page this is happening on so that it can be looked into?
There are a number of pages a ways in the admin area to set permissions and without knowing what page you are getting this issue on it's hard to advise you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lolila Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2006 at 10:05am
Sorry.
admin_group_details.asp  does not work
admin_group_permissions.asp does not work
admin_user_permissions.asp is OK
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2006 at 11:07am
Have you setup and created forums?
If not then this will be the problem as you need to have created forums to set permissions on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lolila Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2006 at 12:13pm
Maybe, I'll try. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2006 at 1:35pm
I didn't think that this could be a problem as being the writer of the software it just seemed obvious to me that to set permissions on forums you needed to have forums to do this on.
However, I have updated the code for the these pages for next version so that if no forums exist on the permissions page it gives a message informing the user that they need to create a forum first before setting permissions.
