MS SQL forum
URL: https://forums.webwiz.net/forum_posts.asp?TID=15972
Printed Date: 13 April 2026 at 1:47pm
Topic: MS SQL forum
Posted By: SUJO
Subject: MS SQL forum
Date Posted: 25 July 2005 at 8:04am
Hi!
I have private server running windows server 2003 + MS SQL 2000. I created blank database, installed forum succesfully - BUT - now I get this error when trying to access it:
Microsoft OLE DB Provider for SQL Server error '80040e09'
EXECUTE permission denied on object 'wwfSpSelectConfiguration', database 'forum', owner 'dbo'.
/forum/common.asp, line 283
I know that probably I did not set up database access correctly - but can somebody tell me where I got it wrong?
Many tnx in advance.
Posted By: dj air
Date Posted: 25 July 2005 at 11:33am
this means the user that is used to connect to the SQL server doesn't have access (execute) permssions enabled within that account
if using Enterprise manager to edit the server, you need to right click the stored procedures and then on the line with the connecting username allow executing permissions
Posted By: SUJO
Date Posted: 25 July 2005 at 12:10pm
done that - SQL server group--LOCAL--databases--forum--stored procedures--wwfxxxx and still nothing...Confused
it's weerd that I have to do that manually for so many lines - isn't there some kind of command or click, alowing the user right away that he/she can do that? Question
I would like to see the procedure from creating the database and user, that can login into the server, opening the database and doing with it all neccesary stuff - read+write+update+execute etc etc LOL
