Web Wiz - Solar Powered Eco Web Hosting
  New Posts New Posts RSS Feed - Problem using RTE in frames
jupiter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jupiter Quote  Post ReplyReply Direct Link To This Post Topic: Problem using RTE in frames
    Posted: 10 April 2017 at 8:03pm
I'm using frames: left panel for navigation, right panel for content. If I start RTE (i.e. the default.asp file provided in the distribution v4.16) in a frame, it works fine in Chrome and Firefox but not in IE. If I load that same default.asp in IE directly, ie without frames, it works fine. Problem when using frames is that I don't get focus in the text area and can thus not type any text. If I use the Word insert pop-up, I get the message "error inserting object in current location".
Any pointers as to a fix would be appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2017 at 9:45am
The only pointer can give is to not use frames.
Frames would stop the RTE from working as it would cause issues with the JavaScript.
Frames are rarely used in websites these days as CSS has taken the place of frames in most instances.
Edited by WebWiz-Bruce - 11 April 2017 at 9:51am
  Share Topic
Forum Software by Web Wiz Forums® version 12.03
Copyright ©2001-2019 Web Wiz Ltd.
Become a Fan on Facebook Follow us on Twitter Connect with us on LinkedIn Community Forums Web Wiz Blogs Web Wiz News
About Web Wiz | Contact Web Wiz | Terms & Conditions | Cookies | Privacy Policy
Prices exclude VAT unless otherwise stated. VAT No. GB988999105 - $, € prices shown as a guideline only.
Copyright ©2001-2021 Web Wiz Ltd. All rights reserved.
