  New Posts New Posts RSS Feed - Problem with picture upload - AspSmartUpl
wrang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrang Quote  Post ReplyReply Direct Link To This Post Topic: Problem with picture upload - AspSmartUpl
    Posted: 08 January 2005 at 10:51pm
When i change the forum to 7.9 it works with upload a picture but now 6-days later it dosent work. I haved tried to change all the upload Component and it still same problem.
My webbhost support SmartUpload and today it dosent work and this error came upp.
Server object error 'ASP 0178 : 80070005'
Server.CreateObject Access Error
/forumet/functions/functions_upload.asp, line 288
The call to Server.CreateObject failed while checking permissions. Access is denied to this object.
http://www.saltvattensguiden.se/forumet/forum_posts.asp?TID= 3737&PN=1
is it some outer thing i can use and mod the forum so it work
Regards
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2005 at 6:26am
Contact your web hosts as this looks like a server permissions problem as they may have changed some security settings on the server which now prevent you from accessing the upload component.
Edited by -boRg- - 09 January 2005 at 6:27am
