  New Posts New Posts RSS Feed - Problem with RTE in forums Web Wiz
morgantip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morgantip Quote  Post ReplyReply Direct Link To This Post Topic: Problem with RTE in forums Web Wiz
    Posted: 18 July 2005 at 2:03am
Hi, Wink
I've got a problem with the "WYSIWYG RTE Post Editor" in my forum.
When clicking Enter :
WYSIWYG = on : a blank line is first inserted before the line
WYSIWYG = off : a break line is inserted
Could you please tell me how to do not to have any "inserted" line when using WYSYWYG mode ?
Best, Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2005 at 4:14am
In WYSIWYG the line break is to do with Microsoft's editing facilities built into IE.
For some reason MS decided that when you hit return it should put in a <p> tag creating a double line space, the way to make it insert a <br> and just move to the next line is to press SHIFT -> ENTER
Post Options Post Options   Thanks (0) Thanks(0)   Quote morgantip Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2005 at 5:54am
Ok,but why is it not the case in your forum and it's working with mine? I connect to both with IE.
I know about the SHIFT + ENTER function but I don't think the users do !
Post Options Post Options   Thanks (0) Thanks(0)   Quote WebWiz-Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2005 at 8:48am
In version 8 which is being tested on this site I have written a new function that detacts key presses in IE and when the ENTER key is detected as being pressed the function jumps in to disable IE's handling of the ENTER key and inserts <br> instead.
